Pain.NET 2.64 released
mrk
mrk
Man of Honour
18 Oct 2002
Uranus hehehe
changelog said:
* Improved GIF save quality by implementing Floyd-Steinburg error diffusion algorithm
* Printing now works in Windows Vista
* Fixed a startup performance problem on some systems that was an artifact of the way the .NET Framework was verifying Authenticode signatures as part of its assembly loading process
* Executable files now have UAC manifests to ensure proper execution privilege and to disable file and registry virtualization in Windows Vista
DOWNLOAD
I'm using remote desktop from work to my home pc and installed the updated version and loaded it when installed. Startup time is now near instant! was taking up to 5 secs before, and this is using remote desktop!
Now my default "quick" image editor of choice. Since installing office 2007 I lose ms photo editor which I was using to cquickly load and resize then resave an image and have been using Paint.NET as an alternative but didn't like how it took a few seconds to load instead of the near instant load of ms photo editor but now that's no longer an issue :)
I ran the update check earlier and found 2.64 out. I downloaded it straightaway; like you Paint.Net is my program of choice for images nowadays. I used to use the GIMP but that was a bit awkward for me.
Just ran it now to test the immediate load up-ness, it didn't load up instantly but is a bit quicker than 2.63 I think.
