12 Mar 2016 at 05:56 #1 snowball1 snowball1 Associate Joined 28 Dec 2007 Posts 332 Location Aberdeenshire Hi, Anyone know where I can find the paint code for a 2010 Fiesta, the numbers on the drivers door plate don't seem to match anything in Halfords! Cheers
12 Mar 2016 at 11:45 #2 Cookeh Cookeh Soldato Joined 21 Jan 2010 Posts 8,442 Location Ceredigion Go to the dealer. Likely the same price as Halfords and you know there wont be any issues with matching. The code should also be in the owners manual
12 Mar 2016 at 11:50 #3 scrivz69 scrivz69 Soldato Joined 6 Dec 2008 Posts 2,813 Location York Put your reg into the Ford etis website it will tell you what colour the car is. https://www.etis.ford.com/vehicleRegSelector.do
