- 30 Sep 2005
What a weekend I've had!!
Decided to paint the spare bedroom (our office basically) grey, and has turned into an utter nightmare. Basically the paint dries a different shade of grey dependant on what you use to put it on with.
I did the tops of the skirting board, and just under the ceiling with a brush and then used a roller for the big areas. There was a few little marks left, so I went over these with a brush.
It's dried horrible. It's all different shades of grey! I've done lots of painting over the years and never seen this issue before. Can't understand it.
Anyways, ended up putting on three coats and looks even worse! Last night I applied a line in the middle of a wall with a brush just as a test. It's dried light grey! WTF
I've searched on google, and think it's what's known as paint flashing. The recommendation is to paint it again (which I have)
anyone had this problem before? If I could roller the entire lot I would, but you can't get the roller everywhere.
The paint is crown matt emulsion city grey. First time I've used crown paint.
Thanks
Thanks
