Painting a garage floor...
Ken
Ken
28 Apr 2004
Hi,
Anyone with knowledge or experience of this?
I've got a bare concrete garage floor with bare brick walls and suspect most of the dust is from the concrete floor itself and dust blown through the gaps around the garage door/frame.
I want to move my Powertec rack and treadmill into the garage and was wondering what I need to do to make the garage dust free and low maintenance in terms of the floor and walls.
Do I need to do anything with the walls?
Can I paint the floor or does it need treating or sealing in some way?
Completely no idea.
Please advise...:p
if you want to seal the floor you could either pva it which works well and stops the dust kicking up or just go to bq and buy some concrete floor paint whatever its called :), Paint the walls with masonary paint? :p
I got some generic floor paint/sealant when we did some work at a shopping mall one time.
Made a big difference to dust and makes cleaning up a damn sight easier :)
Anything that seals the floor will be a boon.
Use a sealant, then paint it with garage floor paint.
I used stuff made by International. I think i did two coats of sealant, and then two coats of the actual floor paint.
Completely eliminated all the dust, which was coming from the concrete floor. Also fit some brush thingers to the bottom of the garage door to stop stuff blowing in through the gap.
Cheers guys. :)
Take it all I need to do before the sealant is to just sweep/vacuum the floor then hose it down?
I painted my garage wall + floor. Made a big difference with the dust and looks a lot better than the dull grey it used to be.
Hold off on the hosing down. All the sealants/floor paints you will be using will be solvent based and moisture will stop them adhering properly.
I've always just used standard grey garage floor paint made for concrete without first sealing and not had any problems.
If you have any damp or oily patches you may have to do some extra preparation to get a durable finish (can't help you with what!).
I wouldn't hose it down, leave it dry.
Use a soft brush and sweep away as much surface dust as you can. Don't use a rough brush, as you will just sweep away more of the floor, creating more dust to clear up.
