Bonjour
So ive been trolling for a couple of days now getting case idea's. Ive never really cared about cases as i keep mine hidden away out of sight. I've spent some dosh on parts and you've probably read some of my previou posts re: stuff ive got so i wont go into details. I was reccomended in my last post to get a PC7+
I'm into the idea of respraying the inside of the case White. I'd keep the black exterior as normal. I'll stick some green cold cathode in ther also
i also really like this
(credit to PinkFloyd!)
which would show off the painted bays nicely. So the point is:
How does the PC7+ come apart? Do all the panels come off leaving me with a basic frame that i can spray? Also, would it be easy to make a perspex full side window? would it screw about with the airflow at all if it didnt sit prefectly flush?
Would you reccomend a different case for the job? i need a lot of space inside but i dont have a lot of money to spend (£80 ish)
Any idea's welcome!
Any idea's welcome!
