Painting Cables
11 Jan 2014
Eíre
I've got a black case with blue LEDs, Corsair Vengeance ram, a blue stick and a black stick, and a blue and black motherboard. I was wondering can I paint cables inside my case such as the sata and PSU cables to go with the colour scheme?
I imagine you could plastidip them ok but as above braiding would probably be the nicer better looking option.
or just do as i do, and remake the cables using white wire ;)
its only worth it with yellows, oranges, whites and reds though (possibly a light blue)
most other colours will be fine on black wire or coloured wire.
You need to enable your trust buddy, to do that click on the trust button on one of your posts and login using your forum account. Tick the box saying 'enable trust' then you should be able yo trust message me.
I can't message you until that's done, if you still can't figure it out, pop another post on here and I'll sort something out tomorrow =)
Done :p I think...
Davido what wire do you use to make your own wires? tempted to do this for my build....
I buy my wire in bulk. Depending on what I'm doing I use 16 or 18 awg wire. Mainly 18 as its a bit thinner, but still can handle it.
Pop me a message and I'll sort you out some if you want, you know you will get the right stuff then and I'll probably be able to do it cheaper than elsewhere.
