painting cases
I will be painting mine this weekend and i will be using the following:
Plastikote Super Enamel Primer.
Plastikote Super Enamel Satin Black.
Plastikote Super Enamel Satin Clear Coat.
Hope that helps.
Any paint should be ok as long as its quality, just make sure you stay with the same brand throughout.
Although if its the whole chassis your doing, you could possibly think about power coating? Better finish, stronger, etc.
Getting my ATCS 840 done for £20 2 colours. bargain :D
+1 for powdercoating, much better finish than anything I've done with a spraycan. The company I used for my antec 900 said they had done quite a few cases.
Where are you getting it done if you don't mind me asking? Since you live in leeds as do I ;)
Plastikote enamel spray works okay; just be sure to be patient, follow the instructions, and don't recoat outside of the times stated on the can.
lucky lol so there is not much prep needing to be done
Shame cuz iv got all ali, and its gonna be such a hassle to prep it before hand
