Painting inside of a case
18 Aug 2012
Hi everyone
I have Lian Li Pc7+ case I have had it for a while and I'm happy with it but I would like to paint the inside black.
Can somebody tell me what I would need in order to do this. If possible links as well please.
Thanks
You could use a multitude of pajnt
Or get it powder coated.
For painting,
Take the case apart, mask areas you don't want to spray, prime it, spray it.
Use wet and dry sand paper if needs be.
Tis that simple!
