painting inside of case
13 Aug 2004
England
hey all, there's this grey layer of paint on the inside of my pc case, if I were to paint it would I need to take it off before priming?
FrannoBaz said:
But the gaps inbetween them makes it too big.
Didn't realise that :o
No way is your sig 4 lines of text, looks like 5 or 6 tbh.
Quote:
Originally Posted by Scuzi
In Soviet Russia, shirt is too sexy for you.
life sucks with onscreen keyboard
4 lines of text. ;)
Any way, this thread can be closed, decided to sand it down, just need a suuny day now :mad: (it's may ffs and it's still raining!)
You shouldn't need to sand the insides of it before you paint it.
FrannoBaz said:
change it or be banned... its up to u
His sig takes up less space than mine (390 x 108 vs 408 x 108 total)
I won't get banned for (not) having a sig which is too big, i've had sigs before which are this size.
Thanks for replying Raikiri , buzz, and malfunkshun, I gave the mobo tray a sand with 400grit wet/dry, though i'll take your advice and just give the rest a good clean. There are some parts which are srayable, but impossible to get to.
Going for a black and white theme with a chieftec dragon, a little bit of red on the fans aswell (xilence's).
Raikiri, bloody nice set up you've got now ;)
Sounds good, got any pics? :D .
My mate painted the inside of his Antec case which is similar to a chieftec dragon iirc.
Will be starting a thread when my keyboard arrives this week, there will be pics in there ;)
That case is almost identical lol :eek: Theres a few more bit's inside that need painting like the cd drive bays and rails.
