Just reading through the painting guide.. it's a little unclear on a few things
am about to change the colour of a beige warrior. I have a few cans of normal car paint in the right colour, the metal panel of the case is no problem.
I'm not sure what to do about the front fascia though. There's just no possible way on earth i'm going to get a vinyl dye to match this paint, and i want to use the paint i have.
If i use plastic primer, can i then spray the fascia in normal paint?
Also can i use conventional car bodyfiller to modify said fascia, and will said primer stick to filler?
any help appreciated
