I was wondering how hard it is to powder coat yourself? Also, I have a black lian li that has a couple of dings on it, what would be the best way to sort these?
One ding on the back is quite big, it's on the corner, the alu is scratched quite a lot so much so that it's taken a wee chunk out of it. The others are just minor on the facia\top\side where it's been knocked or had stuff on it.
I just want the exterior to look good so I can powder paint (clearly not myself) red, so it will match the red\black look I have going with my PC.
You may be better off getting it sprayed on the outside as im sure you cant powdercoat over filler,there are plenty of shops that can help you out just use google
