Palit 2080TI backplate
11 Jan 2007
*̡̡ı ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡
I have a 2080TI from Palit and it has an exposed PCB which is spoiling the look somewhat. I want to fit a backplate and I was thinking if I need a specific one for my card or if any 2080 backplate will fit? Does anyone know or have any recommendations? I don't want to spend too much, not looking for fancy LEDs or anything.
Thanks.
if it's reference then any reference backplate will fit but you might need get new screws that are longer and some washers.
If it's not then you can buy a piece of aluminium and make your own.
