Palit Backplate
10 Apr 2015
Hungerford, UK, Earth
I might be getting a 2060 super. Palit is the best option as the cooler cant exceed the double slots else it will hit a fan. strange thing according to palit website the cheaper card has a backplate but the more expensive OC one doesnt... so it will have to be the cheaper one
My basket at Overclockers UK:
Total: £780.48 (includes shipping: £10.50)​
As above, looks like an error on the Palit website as all pictures I've seen of the latter card show the backplate.
You say you are buying this card because it does not exceed the 2 slots? Ive had the 1080ti and 2080ti pallit cards and its a chunky card. Im sure its two anmd a half slots?
The pictures on the Palit website don't show the heatsink extending beyond the double slot backplate so I'd say the cards are definitely two slot.
I've yet to see a card these days that doesn't use at least two and usually its the best part of 3. Theres always a part of the shrouding or plate that spills over from the 2nd card slot no matter what the pictures indicate
currently have a gigabyte GTX1060 and that doesn't exceed 2 slots..... worst case scenario.. remove fan :)
