Palit GTX 670 Jetstream VGA problems
8 Dec 2011
Glasgow
Okay, well for some reason unknown to me, my graphics card won't/isn't sending a signal to my VGA monitor, I've got them connected using a DVI-I to VGA adapter that was supplied with the card.
I've checked the monitor with another computer and it works, and I connected a monitor with HDMI to the graphics card and it works. So I am wondering if anyone else has encountered this problem before and managed to find a solution or if anyone has any suggestions for a remedy to this problem. Thanks.
I assume you are using the DVI to VGA adapter in the connector labeled DVI-I?
You probably are as it's the only one the adapter should fit.
Your graphics card seems to be working as you've tried it with a HDMI connection to a different monitor.
Have you tried a different DVI to VGA adapter?
