Palit Jetstream 1070 default boost clock
19 Aug 2011
Anyone else here bought a GTX 1070 Palit Jetstream from OCUK?
Mine arrived an hour ago and it appears to have a boost clock of 1860Mhz as opposed to 1683MHz.
Yeah I got the Super Jetsream, and I think it boosted to 1886 or 1913 or something straight out of the box.
The stated boost system is kind of weird. It's a boost but kind of a 'minimum' boost based on available voltage/power/temperature headroom on the card.
I have just the basic Dual Fan Palit 1070 card and it boosts to 1911. I don't mind the fans so much, they're not overly loud at 100%, so I've set a more aggressive fan curve.
Maybe that's why it goes as high as it does.
My 1070 super jet stream boosts to 2037 out of the box. Seems to overclock really well as well but I will probably run it as stock as I only have a 1080p 60Hz monitor
Due to the way the boost works, it also depends what you're running as to how high it'll go at stock.
If you run Vsync at 60Hz 1920x1080 for example, it'll probably only clock to 1500 MHz :p
funny enough boost seems more agressive on pascal than maxwell on low load.
My 970 would sit as base 3d clocks on low load, but when I have low load on my 1070 e.g. 60fps 1080p, it will boost to max.
