Palit jetstream 1070ti
29 Feb 2004
Thinking of getting this to replace my 1070 that had to go back (full refund,not replaced) as it's one of the cheaper 1070ti, while still having the things I want (backplate, good cooler, 0fan mode). On a 5850 now, so can't hang on forever just incase new stuff comes and only a small amount extra on top of the refund.
I've never used palit before so have a couple of questions.
Most of the reviews I can find, that give top reviews are the super jetstream. Far as I can tell the super jetstream is just pre-overclocked/has an overclock profile. There's no other difference, same cooler etc underneath? So other than the oc speeds (which gpu boost mostly takes care of anyway), they are the same thing?
Warranty. Palit is through the retailer right? So in this case ocuk. So other than up to 28days if I ever need rma, it's fine, just a bit slower than others that you can direct rma?
Other than that. Anyone with a jetstream, opinions on them, anything you don't like like, issues?
Thanks.
Ok, thanks, judging by that, most seem happy.
Thread has nothing on whether the superjet stream and jetstream are exactly the same though other than the oc. I know some brands arent identical (slightly different cooler under the shroud) even on similar models.
I think from what I can see is the Super has also got selectable RGB. At least it has on the 1060 that I have.
Both have rgb on the ti at least according to palit's site. Everything looks the same and has the same checkmarks.
There was slight differences between jetsteam, super and gamerock on the 1080s at least according to palit that wasn't listed on their site (https://www.reddit.com/r/nvidia/com...ifference_between_gtx_1080_jetstream/d8b1gye/ ) with the only hint of that being 180w vs 200w (cooler was the same though).
All ti's are the same 180w. I suppose it doesn't really matter then, not going any higher and Pascal gets capped by nvidia limits anyway.
