palomino or thoroughbred
20 Nov 2004
UK
Hi just bought a 2000XP, how do i find out if its a palomino or thourobred, would check with sandra but dont have chip installed atm.
AGOIA stepping
Install cpuz mate, that will tell you :) google is your friend.
I think palominos might have been the last with the codes on the core though?
So if the CPU has its codes on core its prob a pally otherwise a t-bread, cpuz will tell you though :)
