Panasonic CF H1
30 Jan 2019
So I have been sorting through some old computer junk and I pulled out a Panasonic CF H1 I also have the docking station that goes with it. I've just installed Windows 7 PRO 32bit as there was no OS on it.
Its to slow for Windows 10.
Specs are:
Intel Atom 1.8GHz
2GB RAM
SSD 64GB
Its ok for light web browsing and running light weight applications. Its has a barcode scanner on it and a camera which I'd like to see if I could get working so I could make it a bit more useful. I downloaded the drivers from the Panasonic website and installed them but have had no such luck and still have some yellow exclamation marks in device manager.
My understanding is the camera and barcode scanner has to be enabled in the BIOS but there is a password on the BIOS which I don't have. I tried the default passwords but none of them worked.
Is there a way of resetting the BIOS password from inside the unit?
Cheers.
