Panasonic z95b power lead?
22 Aug 2008
Can anyone let me know what power lead is with the Panasonic z95b? I read online that it comes with a 1.5m cable but I will need to get a longer cable when I purchase as it will be wall mounted.
Is it just the standard figure 8 plug or the ‘chunkier’ 2 hole type? I need to find a 3m cable that is compatible.
Thanks.
If it helps, the Z95B uses the standard figure-8 (C7) power connector, not the thicker “cloverleaf” style. Mine came with the 1.5m cable as well, but I swapped it for a 3m C7 lead with no issues. As long as you get a decent quality C7 cable, it should work fine for a wall-mounted setup.
Thanks for the info, I thought it was the standard figure 8 but saw a picture on rtings of the rear of set and socket was different! Maybe that was the American model?
