Panel Lottery
12 Mar 2016
Long story short I've been loosing the panel lottery recently. 3 for 3 on monitors with dead/dim pixels, 2 of which where the new ROG Swift, and out of pocket because of it.
What non TN, G-sync monitors are out there on the market that I'm least likely to be playing the panel lottery with right now?
^^ Depends on the manufacture as in the fine print they class a certain number of on/dim/off pixels on every panel as normal.
I've bought a UHD panel direct from a South Korean supplier and by default they allow up ~8 DEAD pixels on a 8M pixel panel! Luckily mine had none despite the panels being B grade and hence very cheap. You could pay extra so they'd open the box before shipping and check.
Any recommendations for a supplier who'd do that?
