Parallels or VMware
19 Oct 2004
Newcastle Upon Tyne
Hi guys,
I have a MacBook which I'd like to run Vista and XP on.
Which would be best to buy parallels or vmware? Or Bootcamp?
Are there any advantages/disadvantages one over the other?
Cheers in advance
So far I've only used vmware server on XP, so I'll be interested in this too.
I have the beta for vmware fusion but I've not had chance to try it out on the mac.
My recommendation would be VMWare Fusion as I think it will eventully be the better product. It is still in beta at the moment and so is free which is fantastic because it performs just as well as if not better than Parallels, it is certainly better in 3D and USB support.
I have 1 Windows only application ( :rolleyes: ) and I used to use Boot Camp but then tried Parallels and it installed fine but becasue it needs a USB dongle I couldn't get it to work plus (as with all emulators) Win XP will require activation and will fail if it is OEM. What I did was to install Win 2k under VMware and the USB dongle worked perfectly with the program. So, for me, VM has the edge.
Try both to see what is the best for you, they are both great solutions and leaves us Mac users spoilt for choice. :)
i have tried both parallels and vmware and have decided to go with vmware fusion. It works really well. The only thing is that it raises my MBP temperatures because of the high CPU usage but maybe thats as its still a beta and maybe the app isn't fully optimised.
