Parallels / VMWare / Virtualbox
Man of Honour
19 Oct 2002
Surrey
Is there any significant reason why I'd want to run Parallels or VMWare over Virtualbox, considering that VB is free? I've been using VB on a Windows machine for some time and am very familiar with it.
Performance. It's quite possible to game in Parallels (I run an Eve client in it at 60fps) and that can't be done in VB, I tried!
I tried VMWare and wasn't impressed with its lack of speed, will give Parallels a try before buying/going Bootcamp. Trying to avoid both at present if possible lol
Parallels allows for complete application integration through cohesive mode. In that virtual machine applications can be launched without having to startup the virtual machine each time, similar to XP Mode in WIndows 7. Not sure if VMware Fusions unity mode can do that aswell so will stand happily corrected. :)
Thanks so far.
The Macbook I'm getting isn't really powerful enough for gaming so I will be keeping my gaming PC too. Virtualbox has supported 'seamless mode' for quite a few years which sounds similar to the coherence/unity mode for Parallelis/VMWare.
I can make my VM on my iMac (2gb ram 2.4 duo) play games at decent settings.
Have you set it all up right?
Paralells looks great, but at the time I got VMware cheap becuse of a friends licence ect. If I were to but any at full price I would have done the Bootcamp route.
I have tried bootcamp and Paralells, and I do prefer Paralells, however I would reccomend VM because of its massive forums with loads of people that will help you if anything goes wrong (Which all 3 will).
I'm trying to put across both sides of the argument, so I don't sound like a bias n00b, but I think that VMware is best for somebody that isn't gaming. I use it for VB work abd to test programs out on, and it works above + beyond the COD for it.
There's very little in it atm.
