Parp for Emily(etc)
11 Oct 2006
Wiltshire
Emily, please ask your father to help you pack as I'm afraid you'll be moving back to cell 17 within the next twelve hours or so. I suggest you stay packed as Ba will be rampaging through in a few days and is likely to be less courteous.
Starting work on Hydra's new water cooled home tonight so at some point my production will drop off to about 20k:(
Not sure quit when,got to get the rads mounted and make up a custom motherboard tray etc etc.
Might have to hold up in cell 20 for a while to get her sorted:D
Thanks for the parp, wasnt really much I could have done to stop you.
Hopefully with the release of the 580 Ti cards there may be a few second hand 460s come up, could do with upgrading Ems cards, would save on lecky as well.
Im on the lookout for an i7 920 for a second workstation if anyone here is upgrading to SandyBridge. I know SB isnt much of an upgrade in normal use but looks like it would make a great folding CPU.
Best of luck Team 10, keep up the good work.
Tom. ;)
