Partial new build advice
11 Nov 2009
Edinburgh
Looking to get a new case, motherboard and CPU possibly RAM but hoping for advice on that aspect.
Case: Phanteks Enthoo Evolve M_ATX
Mobo: Asus TUF B450M-Plus
CPU: Ryzen 5 2600x
The RAM I currently have is Avexir Core Blue Series 16GB PC4-19200C16 2400MHz will this be OK to use?
I am looking to drop a RTX 2080Ti at some point so also hoping that my choice will work well together?
Something different with the case
My basket at Overclockers UK:
Total: £510.58 (includes shipping: £11.70)​
2400hz would hurt the 2600x performance. And hope with the 2080ti you'll be gaming ultra wide 1440p or 4k ?
Case is a definite no no as I loath black cases but the rest looks good.
Unfortunately although I have found a white version I have discovered it is too wide for where I want to put it, thanks anyway.
