Partition a usb drive
28 Feb 2006
Beds
Whats the easiest way to partition a usb drive?
I know you cant do it in windows as it sees the drive as removable media. Ive tried the Lexar tool but that doesnt seem to work.
Any ideas?
i have been given a 2gb pen and only need to use 1gb. this is for something im doing at uni so my data can only be stored in a 1gb space.
gparted live cd
Windows may or may not be willing to acknowledge the second partition, I'm a little hazy on this.
I got a usb bay for my old laptop hard drive, which was partioned in 2. I managed to remove the partitions in Windows, and both were recognized as separate drives. I see no reason as to why it wouldn't work.
ive tried 2 different pens and windows 7 disk management doesnt allow you to create partitions on it. i havent tried gparted yet.
Windows disk management won't let you do this. Not sure about diskpart, but probably not.
gparted most certainly will do it.
Last time I checked, win XP will only recognise 1 partition on a removable USB drive, shouldn't be a problem if you only need to use 1 partition. There is a windows XP driver on the net that allows you to see the extra partitions though.
I second GParted/QTParted, should partition it fine.
I managed to sort it out. The Lexar tool only works if the usb pen is formated in fat32. I managed to created a new partition using gparted
