Partition magic and Acronis help
12 Aug 2005
Hi there
I recently re-formatted my hardrives and re-installed xp, my set up is as follows:
2 x 200gb sata hdds in raid 0 on sata-partitioned by partition magic 8.0 so c=operating system programmes etc and d = data
1 x 80gb hard drive on ide - use this for back up etc. This is labeled-E.
so i installed op system and then used partition magic to partition c drive and then loaded all programmes on to c. once finished i did a back up image using acronis true image 9.0. This i took from the c drive and kept on the d drive and another copy on the e drive.
A little later i wanted to check that it had worked and now i am getting error messages when i try to recover "the selected partition contains the following error: MFT bitmap corrupted. Please note you cannot change the file system and size of this partition. It is reccomended that you check thesepartitions after restoration with yoru operating system disk tools"
so i did some disk error checking on all disks and all seems fine. I think it has something to do with my partitions maybe. Or it could be something to do with my ide drive as this is labeled disk 1 in partition magic and my sata drives are labled disk 2.
any help greatly appreciated
