Partition or not?
27 Aug 2004
UK
I've always had a single hard disc in each of my machines, formatted in to two partitions - one smaller for the OS and all program files, the larger for all my documents, photos, music etc.
I've done this for convenience (I like having a separate 'drive' for documents), and was wondering if there is a better way?
My laptop came with a C: drive labelled OS, which has everything on it, and a 10GB D: drive for Dell's recovery stuff.
When I get Windows 7 I'm planning on formatting and going for a 20GB OS/program partition and the remainder for documents. Is there a disadvantage that I'm missing? I'm not sure that I'm fussed with Dell's recovery stuff.
With a single disk there isn't a significantly better way I can think of. Your current setup is pretty sensible so long as you are backing it up.
20GB is nowhere near enough though for W7 though, I'd go for at the very least 30GB (I'd recommend 40-50 depending on how much storage space you can spare, just in case) as Windows alone takes up around 15GB, plus you'll need a pagefile and then somewhere to put the programs. I'm using a similar setup only with documents on the OS drive as well and it's taking up 25GB total.
Cheers, I've got loads of space at the moment on the 640GB desktop drive, the laptop is only 250GB though. I'm looking at a NAS to centralise storage. I back up on to a WD MyBook at least once a month.
