Parts Size Query / Power Consumption / RAM Question
30 Sep 2004
Wiltshire
Ok whilst im waiting for the G0 steppings of the Q6600 to come in I started to worry about case size and motherboards.
My plan is the above processor with a
Antec P182 Super Midi Tower Case
Asus P5K Deluxe WiFi Intel P35 (Socket 775) PCI-Express DDR2 Motherboard
Thermalright Ultra-120 Extreme Heatsink (Socket AM2/LGA775)
Noctua NF-S12 1200RPM 120mm Silent Case Fan - 3 Pin
and my other size concern
Leadtek GeForce 8800 Ultra 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Will the case fit this confortably and does the motherboard fit that cooler ?
Now given the parts I will be running including a couple of CD drives, probably 3 hard drives will this PSU i currently have be sufficient or should I invest in a larger one ? I was planning on OCing the CPU.
Seasonic M12 Modular 700W Silent ATX2.0 Power Supply
last one
I won some of this
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit
Can I just buy another set to make up my 4GB for my new PC ?
As always the advice is most appreciated and taken on board as I await the CPU coming into stock !
thanks all
Not hugely knowledgable about these kind of things, but I imagine that 700W is enough for that build.
700W is a lot.
