Parvum Build Project "Dark" mini ITX Build
7 Apr 2009
Will add hardware pics/specs shortly and will start adding progress pics of the Build.
Case and parts:
Parvum Systems Veer 1.0 ITX Case - Blacked Out
Asus Z170I PRO GAMING S1151
Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Black
Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor - Retail
Watercooled titan X EVGA
1 x be quiet! Silent Wings 2 PWM - 80mm
3 x EK Water Blocks EK-Vardar F4-120ER (2200rpm)
Samsung SSD 950 PRO 256GB Drive
Watercooled parts:
EK Water Blocks EK-XRES 100 Revo D5 - Acetal
EK Water Blocks EK-Supremacy EVO - Acetal+Nickel (Black)
ACool NexXxoS ST30 Copper 240 Radiator
ACool NexXxoS ST30 Copper 120 Radiator
Progress so far......
Radiators and Fans fitted - added Block and memory to motherboard but Samsung 950 is in other machine so cannot install Motherboard until day of full setup. Had a pain added the EK CPU Waterblock as the backplate was not letting one of the screws thread in properly so everytime i added thermal paste and started screwing together that one would pop off (had to do this 3 times lol)
A lot of hard work last night. Finished at last!! Cabling is a mess in the back but i'm not too fussed about having braided cables also went for bendy tubes as i have never attempted hard tubing and at this small level i can imaging it would be a nightmare.
It was a lot harder to connect the cables this time around but i am happy with the finished product.
Looks a lot better in reality :)
Incidentally temps are amazing now. I have the D5 pump running around 1 1/2 the temps now ide around 20-23 when i my massive phantec enthoo primo they would idle at around 26-27
PSU Behind mobo? Looks lovely!
Yes, managed to fit my huge PSU in the back which i am happy about (it buliges out a few mm so the side panel is not fully flush but may go for a smaller quieter PSU and get some custom brading in the future. Also put my 3.5 inch HDD 4 TB drive and an SSD for backing up the OS.
I was worried about having the Resevoir/Pump combo horizontal as the outlet what quite high so though there may be an issue with circulating the water but it seems fine.
I was also nervous about drilling holes for the res brackets but drilled without any issue.
Looking good mate, always impresses me how people fit watercooling loops into such small cases :)
Thanks, appreciate that :)
Its my third custom loop ever lol. I think the main issue will be the annual draining by the time i have to do it again i will have forgotten how hard work it was.
May take a shot at hard tubing next time.
Have you got any shots of the back of the case? I'm just about to order this case and would love to install a 3.5" drive.
At the moment it is just stuck on the back with some tape i removed the SSD holder and the SSD drive is stuck over all the wires lol (will be getting some 3M dual lock soon)
It is a cable nightmare at the back at the moment and everything is just crammed in there with no cable management so unfortunately i cant really show you the back yet.
Stuff will fit ok though.
When it is more presentable i will do a pic.
Very nice work mate, clean and slick, really impressive. One day i'll grow the cahoonas to try wc...
I actually have a feeling that doing hardline tubing will be easier as it was quite a problem trying to screw the ends on the end of the rubber tubing (maybe my tubing was thicker this time around)
But once it is set up with the rubber tubing it makes it easier to visualise how you will do the hard tubing and also helps you to work out which additional 45° or 90° bits you will need.
May attempt it in January with black fittings and grey coolant or maybe black! I Think that will make it look even better :)
Would be helpful if someone could advise which size fittings i would need with which rigid tubing.
Also for the Pump i think the D5 Mod Kit would make it look much better:
https://www.overclockers.co.uk/bitspower-d5-mod-kit-wc-328-bp.html
From my own planning there seem to be 3 sizes of hard tubing. Sizes are listed as OD/ID in mm
12/10
13/10
16/12
There's also Imperial measurement versions since the American's haven't quite joined us in the 21st century:
1/2 inch
5/8 inch (which is essentially the same as 16/12)
Bitspower and E22 offer 12/10 tube, Primochill do 13/10, EK do 12/10 and 16/12, Monsoon do 13/10, 1/2 inch an 5/8 inch
You also get tubing in both acrylic and PETG but I've not paid too much attention in the differences - I think PETG is supposed to be easier to work with as it bends at a lower temperature, but is a more fragile than acrylic so can't take as much of an impact (not that you should be kicking your computer anyway).
So from there just choose the fittings that match your outer dimensions, but note that you need specific hardline compression fittings or push fittings, not soft tube compression fittings.
So you're looking at EK-HD and EK-HDC fittings, Monsoon Chaingun and Free Centre, Primochill Ghost and Revolver. Bitspower do a load too, as do Barrow (seemingly the same OEM as Bitspower but without the garish logos).
You wanna hold my hand? My very first water loop will be hardline and frankly I'm bricking it! We could have cahoonas together lolol
As long as it's just your hand... :eek:
Hmm, I think I'm going to stick with flexi as I can just see myself loosing my **** trying to do perfect bends on hardline. My skills are nowhere near what is required to meet my OCD expectations...
I'm still in shock with regard to the lower temperatures - on full load playing games etc processor and titan X doesn't seem to go over 40-45.
Will have to test this theory a little more over the weekend when i do some gaming and run some stress tests.
Noise levels wit regard to fans etc is also good - I am going to replace the current corsair 750 watt PSU with a smaller silent one as i can probably get away with a lesser Wattage one now so it will be even quieter
Do you think i could get away with a 550 or 650 one?
