- 2 Aug 2010
- Egypt/ Surrey
Do I get the new Parvum revision case? Or do I get the Corsair 540.
Both will be Watercooling an i7 2600k and a 780. Mayhaps stumble on another 780 in the future for Sli maybe not.
Which would you go for? Which would you suggest for me?
I am struggling, anyone water cooled both or have experience which can help?
I am using a m-atx gene motherboard. (May put under in the future too...
) you're limited to small and thin rads. 2 rads will do it, either noise or temps will be higher that's all. I opted for single card but an extra 360 so noise could be reduced while still getting decent temps.
