parvum orange and black water build log
It's not a design flaw
If you have air in the system, it wants to rise to the top
You can't try and pump the air down through the pipe
All you had to do was turn it upside down or tip it backwards so the air can go back into the res
hope you get it sorted, i was looking at that cpu block and coolant in white but all i know is outer most hole in block is the outlet and middle one in .
Sticking 4 10cm uv cathodes in the case in the morning will update with photos once my waterblock and backplate arrive, i have had a lot of fun doing this build goto give a shout out to the parvum guys and overclockers :)
looks nice, looks different what you done to it, did you sort the problem with air bubbles.:)
Changed the tubing from half inch to smaller ones and used uv green liquid rather then that mayhems pearl one, yea all sorted now had to raise the res to the highest point when bleeding.
i was looking at the supernova coolant, its put me off now, how is the res was thinking of that one or the EK one as its got a extra port which i was gonna put a drain on.
