I'm getting some cables braided and instead of buying a pre-braided extension, I'm getting a cheap 24pin extension. In order to work out how much braid needs to be ordered, can you measure the distance from the motherboards 24pin to behind the motherboard tray?
I'm guessing 15cm, but without the case it's only a guess, and possibly wrong. I'd be looking to tape the end of the 24pin on the back of the motherboard tray, so please take this into account.
Length in cm will be fine, thanks
