Parvum systems 1.0 build Advice Please (which Rads?)
14 Apr 2010
Milton Keynes
So I will be getting myself one of these cases which I have seen in the flesh at one of the iseries and think they look amazing. Also its the only case I can see that's a small Matx but fits two 240 Rads in with no problem.
Just looking for a little advice on the case, recommend layout or rads to use?
Currently this is my planed hardware
PSU: AX850
CPU:
Mobo: Asus Rampage IV Gene
Ram:
Gfx: 680 EVGA (will be x2 in the future)
Storage:
3.5 (possibly x2 if it will fit)
2.5 (possibly x4 if it will fit)
Cooling:
Ek Blocks (ofcause!)
D5 Pump + Ek res
Monsoon fittings 1/2 - 3/4
Radiators I dont have yet and am very undecided, I am thinking two of these
Alphacool 35272 NexXxoS XT45 Radiator 240
A little on Layout
As I plan to have quite a few drives if possible I won't have allot of space in the back of the case. So I am hoping to put the pump with res on the floor of the case in-front of the front facing 240 rad. I've seen this before but I think it was a DDc Laying pump and not the D5.
From Parvum's website:
Radiator thickness: We advice 30-35mm thick rads but 45 will also fit in the front.
If you want matching brands, maybe consider an ST30 and an XT45 perhaps?
