As requested
Three Fan Bundle - Parvum Systems F1.0 Performance Fan - White @ £28.99 inc VAT
Parvum Systems Cases offer a unique take on a system modding project and to compliment the impressive acrylic case range, the F1.0 fan has been launched.
Working in conjunction with Premier cooling brand Alpenföhn, the Parvum F1.0 is based around the high performance Wing Boost 2 cooling fan. The Wing Boost 2 offers excellent performance in both air and watercooling applications and compliments the Parvum Systems ethos perfectly.
In addition to the Parvum branding, the Parvum F1.0 White edition is an exclusive colourway to Parvum Systems.
WB2-Technology
Many users ask themselves…what are WingBoost´s? WingBoost´s are ridges on the
impeller that guide the air on the air-inlet side of the impeller. Using the WingBoost 2
technology air turbulences are reduced wich leads to a lower noise level at full speed.
S-Shape geometry
With the improved S-Shape geometry we could reach a higher static pressure compared
to conventional designs.
HD-bearing:
The new developed HD Bearing (Hydraulic Bearing) reduces friction noises to a minimum and thus enables to a quiet operation.
Plus Funktion:
The new WingBoost 2 is equipped with a "plus-function".
That means that a Y split cable has been attached to the PWM connector for a
second fan. Thanks to this split cable it is possible to control additional PWM fan
with the same PWM connector on the motherboard instead of using a cable adapter or a 3pin connection.
Specifications:-
- Dimensions: 120 x 120 x 25 mm (W x H x D)
- Dimensions: about 166 g
- Material: plastic, rubber
- Color: Black, White
- Volume: max. 18.2 dB (A)
- Speed: 500 - 1,500 r / min
- Air flow: max. 106 m³ / h
- Voltage: 12 V
- Connector: 4-pin PWM (with Y-switch)
- Accessories:
- 1x Cable 4-pin to 3-pin (no PWM)
- 1x Adapter 4-pin PWM-to-7-volt Molex
- Adapter 1x 4-pin PWM-to-5-volt Molex
- 4x Gummipins for decoupled housing mounting
Was £35.96 Inc. VAT
Only £28.99 inc VAT.
ORDER NOW
Three Fan Bundle - Parvum Systems F1.0 Performance Fan - Black @ £28.99 inc VAT
WB2-Technology
S-Shape geometry
HD-bearing:
Plus Funktion:
Specifications:-
- Voltage: 12 V
- Accessories:
Was £35.96 Inc. VAT
ORDER NOW
