Hi
I'm considering getting a Parvum case and wanted to ask a few questions:
1. How are they for building a silent build in terms of vibration and general noise. The 80mm fans at the back could be a problem.
2. How easy is the acrylic to clean, if I get a white case would it get filthy.
3. Do you see the cases having long term use in terms of the construction quality, for example will the screws damage the acrylic if you modify the build a few times and take it apart. What about moving them around, are they sturdy like a steel case?
Thanks
Thanks
