Hi all, Not sure if i've replaced a faulty part that wasn't the real problem.
The cars a 1.8T passat. Started the car and all fine then got a mile down the road then first cough that rapidly built into very bad kangarooing and at idle the engine was going from stalling to reving up to 2000 rpm. Had to get it from where it was and drove it about 5 mile by constantly varying the throttle which seemed to stop it cutting and missing as much but used easily 2 gallons in that distance.
First thought was the icm (1.8t aeb engine) but tested it and that was fine, then unplugged the MAS and tick over stabilised so ordered one. In the mean time i got a vag cable which also confirmed a MAS intermittent reading.
New MAS in and tick over normal but still a cough/ hesitation when gradually lifting off throttle at low revs and woolly power. Scanned it again and got this code:-
Friday, 11 October 2013, 19:15:48.
VCDS-Lite Version: Release 1.2
Control Module Part Number: 8D0 907 558 E
Component and/or Version: 1.8L R4/5VT MOTR HS D02
Software Coding: 04001
Work Shop Code: WSC 05314
VCID: 33199CCF122D
1 Fault Found:
00561 - Mixture Adaptation
13-00 - Adaptation Limit (Mul) Not Reached
Cleared that code, took it for a couple of miles then red lined it in first and second and again woolly and lacking in power until 5800rpm then sudden jolt of full power. Fault checked it again and now getting this:-
Friday, 11 October 2013, 20:17:37.
VCID: 33199CCF122D
2 Faults Found:
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
00575 - Shareware Version. To Decode all DTCs
08-10 - Please Register/Activate - Intermittent
Peak MAS reading is 160gs but reading Ross Tech website the suggest it should be around 120gs.
Also looking at the lambda sensor at tickover its all over the place. Does that look right or is it just the managment trying to find a mixture causing the erratic readings? though it should be 1 at tickover!
http://www.youtube.com/watch?v=B_BKfYB6jD4
So what you think, cheap and nasty MAS or does it look like lambda has gone too possibly by driving it when the MAS went down. Also seen suggestions of similar and throttle body cleaning needed?
Any help or suggestions appreciated.
VCID: 33199CCF122D
1 Fault Found:
VCID: 33199CCF122D
2 Faults Found:
