Passing querystring to iframe
8 Mar 2005
London, UK
I thought this would be dead easy but no..... I need to embed a page inside another and pass the query string to it from the parent to the embedded page..
Querystring
Code:
?Tick_ID=ABC12345
Code:
<iframe id="MyIFrame" src="https://website.domain.com/info.asp?ticket_id=<%Tick_ID%>" runat="server" scrolling="auto" width="100%" height="768px" frameborder="0"></iframe>
I don't believe I need any code behind it but clearly I'm missing something as the string is not passed.
TIA!
Code:
<iframe id="MyIFrame" src="https://website.domain.com/info.asp?ticket_id=<%=Request.QueryString["Tick_ID"]%>" runat="server" scrolling="auto" width="100%" height="768px" frameborder="0"></iframe>
Code:
Code:
Parser Error Message: Server tags cannot contain <% ... %> constructs.
Hmmm, strange error. I'll continue to play ...
Replacing " with '
Code:
<iframe id="MyIFrame" src="https://website.domain.com/info.asp?ticket_id=<%=Request.QueryString['Tick_ID']%>" runat="server" scrolling="auto" width="100%" height="768px" frameborder="0"></iframe>
Renders the page but again not passing the querystring.
So to be clear, for my understanding. I have a selection gridview on one page which directs to another page on the same site with a querystring.
Code:
https://firstwebsite.domain.com/somepage?tick_id=ABC1234
Within somepage on the first site that which contains iframe to another source address where I wish to pass the querystring from the first.
Code:
<iframe id="MyIFrame" src="https://secondwebsite.domain.com/anotherpage?ticket_id=<%=Request.QueryString["tick_id"]%>" runat="server" scrolling="auto" width="100%" height="768px" frameborder="0"></iframe>
This should iframe to
Code:
https://secondwebsite.domain.com/anotherpage?ticket_id=ABC1234
The above should work? I'm getting myself in a right pickle with this. I've also now confused myself with "tick_id"; I may be incorrectly thinking the Request.QueryString requires "tick_id" to be defined in order it then passes the string "ABC1234".
yeah it should work.
try just printing
to make sure the value has come through properly.
and try your iframe without passing it in just to make sure it doesn't error
<iframe id="MyIFrame" src="https://secondwebsite.domain.com/anotherpage?ticket_id=x" runat="server" scrolling="auto" width="100%" height="768px" frameborder="0"></iframe>
and try passing it in like this:
<iframe id="MyIFrame" runat="server" scrolling="auto" width="100%" height="768px" frameborder="0"></iframe>
// may be syntax errors here, but you get the idea
// also note this sanitises input from the querystring, which is a vulnerability otherwise.
this.MyIFrame.Src = string.format("https://secondwebsite.domain.com/anotherpage?ticket_id={0}", int.parse(Request.QueryString["tick_id"]));
Tried this quickly
Code:
which generates
Code:
Compiler Error Message: BC32017: Comma, ')', or a valid expression continuation expected.
I'm off to Hoxton now so will likely pick this back up again tomorrow.
I much appreciate your support (and patience) with this!
OK; sorted it. Need to define it in code.
Code:
 'Declare variable in global scope
    Protected Tick_ID As String
    Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        'set the value
        Tick_ID = Request.QueryString("Tick_ID")
    End Sub
Called via
Code:
 <iframe id="MyIFrame" src="https://website.domain.com/info.asp?ticket_id=<%=Tick_ID%>" scrolling="auto" width="100%" height="768px" frameborder="0"></iframe>
