I've been using this script for a while where I can put different variablle in the URL and these will get passed to the php script eg
and then in the script you can run
and it will print out "foo bar", but it doesn't seem to be running on my local machine. I'm running XAMPP which uses apache and what looks like a normal php setup. Is there anything I should check which might be stopping this?
Code:
index.php?foo=foo+bar
Code:
<?php print $foo;?>
