Passive cooled PSU's
23 Nov 2006
Hi
I have a coolermast extreme power 650w psu.
To be honest the drone of it does my head in.
Is there such a thing as a passive cooled PSU?
I was round at a mates and he was using an iMAC which was blissfully silent!!
J
jup. they exist, but not for 650w ratings. asuming your pc isnt stacked, and that your not overclocked like a loon, they should cope however. there are a variety of modles arroudn the 300-400w rating. antec did sell a 500w one, but that had a fan for higher load levels. shop about. and maybe invest in a plugin wattage meter. if your psu is drawing less than say, 300w loaded from the wall you should be ok with a 350w unit (strictly a 300would be fine also, or even a 250 - as 300 wall wats is less than 300 dc-side load watts, which is hwo psu's are rated but some headroom is wise!)
you could just buy an over-rated PSU with active fan control...lol
it's amazing how quiet a 1000W PSU is when only drawing 400W ;) :D
The Antec Phantom is good, as long as it fits in your case and you don't stress it too much
Hi
J
You should remember that iMacs are fabricated out of what are essentially laptop components...
As posted above, there is no need for a 1.2kW PSU in a modern system... even a modern, high-end gaming system.
There is a common misconception that modern systems need 500W+ PSUs. This is not the case in the vast majority of systems. Don't take my word for it - http://www.behardware.com/art/imprimer/670/
im fully aware of this. i believe my advice remains valid however:
find out how many watts you actually need:
get a psu to suit with some headroom. especially if your running it passive...
and realise also, OP has no spec in sig, so it could be a overclocked FX74 (dual cpu, dual core) with 2 hd2900xt's in xfire and 16 hdd's.. which really would warrent a 600+w psu.
Your advice is perfectly correct, I was just adding that link to reinforce your point.
I did my own testing on an outrageously overclocked Pentium D system with an 8800 gfx card as I was wondering if my old 480W PSU was still going to cut the mustard. To my surprise I couldn't make the system draw more than 280W continuously.
1.2KW PSUs are for people with clear sided cases with neon lights :)
