Passive cooler for a 2Ghz Athlon XP Socket A
A 2Ghz athlon would get quite toasty if it was passive :eek:
My advice would be to get really quiet air cooling
aye i was thinking the same thing, but with all the newer heatsinks out of which some are passive i was hoping i could get lucky :)
Which chip is it? Iirc, some of the later bartons might run alright with a passive heatsink as long as you have good case airflow..which will be loud :p
Perhaps if you underclock/volt it slightly?
I'm guessings it's a XP 3000
And a media PC doesnt need that much of a fast PC does it? So yeh, underclocking it could be a good idea
its extremly hard to run a socket a cpu passive. i couldnt do it with a tbred running at 1ghz/1.1v, temps still rose to 60c in minutes running superpi. for the hassle its not worth it. just get a big heatsink with a big slow fan. you'll hardly hear it anyhow.
Well the biggest thing going for a Socket A is a Big Typhoooooon. Not sure if that'll fit in a media pc though :p
james.miller said:
might do. depends how high it is. It would fit in my silverstone i think, but my scythe ninja wouldnt lol
hehe sythe ninja didnt fit :) (i tried it on his pc and it stuck out the top so you couldnt close the case:P), a zalman aeroflower wouldnt fit either because it was too wide and slightly too tall
doh friend read the numbers wrong its actually a 1.6 i asumed it was a 2400 :) :
http://www.cpu-world.com/CPUs/K7/AMD-Athlon XP 2000+ - AX2000DMT3C.html
guess ill recommend him a Big Typhoon, his current one is stock so sounds like a vaccum cleaner under his tv ><
zalman cnps 7000b would be very quiet on the lowest fan setting and would cool enough. I overclocked my socket a and would forget to turn the fan up when playing a game, I still rarely had a crash all the same.
Completely passive is only going to work on a mobile chip running at 1v or something silly like that
Hi, On my old rig which the cpu is a AMD Athlon 3000+ skt A, I used a gigabyte G-Power pro......and it kept the temps down to a nice 33c idle and 45c under load.
