Passive cooling an i5-6500, Nuts?
19 Oct 2002
The land of Cows n Grass!
If I wanted to build an ITX with an i5-6500, would I be asking too much to have it passivley cooled in a custom itx case? The case has a bespoke heatpipe setup including the side walls acting as radiators.
Everything in it will be running at stock.
Wouldn't have thought that would be out of the question at all. You could maybe even undervolt the CPU a bit to help with temps. I would just make sure you have enough case cooling/airflow.
Well that's the spec'd power for the 6500, so I'd go for it.
Depends a bit on the usage too. If you're going to be pushing it I'd be less confident, but for general use I'd take the gamble.
I would have thought it'd be fine. How long do CPUs run maxed-out under normal office workload anyway? Realistically it's going to be at idle clocks for the majority of its time.
It will spend its life as an office business related machine, browsing, videos etc. The current rig is really struggling with things now (Abit AI7 sk478).
My initial plan was to use an old s775 board and xeon L5420. This one sits at 50w so its not much off the 6500. So things changed when I grabbed an Asus H110i Plus D3 and the 6500.
Nah, nowhere near the edge. The case will be designed to comfortably cope with a 65W TDP chip. Short of running all cores balls to the wall when gaming or encoding media it'll spend the majority of the time sipping power in a sleep state typically.
