Passive CPU
12 Jun 2005
Hi there,
I am looking to create the fastest passive PC i can get.
Basically, i am wondering what would be the best CPU to use. I am guessing it would be the mobile CPUs, but i am unsure of whether i can run them passively?
What are you comments/suggestions on this?
Thanks.
Do you want pumped water passive or air passive. And if it's air passive, are you able to use a specialist case like the Zalman TNN or the mCubed Borg?
I built an overclocked E6300 (3GHz with a Passive 6800 PCIe card) system that was completely passive in an mCubed Borg case and my current home PC is a fully passive pumped water system that started out as a Zalman reserator based unit and has expanded to a 10-link Cape Cora. I have plans to build a 20-link, but lack of funding is getting in the way at the moment ;)
If you are prepared to use a special case then you can use almost any processor.
The Thermalright HR-01 (775) has been successfully tested fully passive with an X6800 (stock speeds) so I would say if you heatsink is adequate, you could use any processor.
WJA96 said:
My current home PC is a fully passive pumped water system that ... has expanded to a 10-link Cape Cora.
I'd love to see piccies of that - I've been thinking along similar lines but not sure how practical it would be in terms of heat dissapation and the difficulty of putting it all together. If you could post a pic or two in the water-cooled cases gallery that would be great! Cheers!
I'll get some tonight when I get home. They are not difficult at all to build - You can either get Alphacool to build it for you or WelshTom builds them too, I think, providing you buy all the bits you can from Overclockers, of course.
My AMD64 3700+ is running passive with the help of an Arctic Freezer 64 Pro heatsink, and a large roomy case. Hasn't combusted yet. :D
Though the temps are a little on the high side.
For the people that are referring to the Core 2 Duo, are you referring to the mobile chips?
I was thinking of getting an Mcubed case, but they are expensive at 300 quid.
