pointless to run passive since a scythe ninja and even a super slow 500rpm fan which will be dead silent is doing to be 3 times better than running truly fanless.
... uses a low-power processor (65W) Athlon 64 X2 4600+, with a fanless Thermalright SI-128 in a desktop case (Antec Fusion).
Bear in mind the orientation of the coolers fins - in a desktop case, the Thermalright's fins are vertical, allowing warm air to flow upwards through them, but this would not be so in a tower, so the warm air would get trapped between the horizontal layers of fins. In a tower case, the Ninja or Tuniq Tower would be better passive choices, since then, their fins would be vertical.
