Passive HTPC case
Don't know anything about that case. It does look quite good but a bit expensive once you add in the heat pipe setup for your particular CPU.
The wesena ones (might have a new name now, streacom I think) look pretty much the same, priced around the same mark and get good reviews so I'd go with one of those instead
