Recently fitted another 2GB of Crucial Ballistix 6400 Ram, and reckon a bit of passive cooling on the dimms (and surrounding area) would be helpful.
I intend keeping things simple so thought about simply mounting an Akasa AK-182-L2B Amber Ultra Quiet 80mm Fan inside the case and directing the airflow towards the ram, the only problem I have is, is there some kind of bracket thet I could attach the Akasa fan too, so that I can then in turn fit the bracket (with Akasa fan attached) somewhere inside the PC Case (Lian Li PC-60).
Or any other simple suggestion would be welcomed.
Many thanks.
Many thanks.
