Just stumbled upon this software. Anyone know if it is reliable or not?
http://www.passmark.com/products/bit.htm
I think all these stress tests are pointless, they just show the maximum heat output. You can have an overclock stable for these and as soon as you play a game you can crash.
Well, if that happens then you were clearly doing the wrong stress test for the system you use.
There's no reason to do large CPU only tests if you game heavily, in the same way stressing the GPU tests when you do heavy CPU work
