3 Dec 2006 at 14:34 #1 nemtizz nemtizz Soldato Joined 16 May 2006 Posts 14,699 Is this possible? Can i download something to do it?
3 Dec 2006 at 14:55 #2 bledd bledd Don Joined 21 Oct 2002 Posts 46,890 Location Parts Unknown this might be similar to what you're looking for.. http://www.truecrypt.org/ if its a shared computer (and has xp pro on it), then use file permissions to only allow your user access to the folder hiding the porn is it?
3 Dec 2006 at 14:57 #3 NathanE NathanE Soldato Joined 21 Oct 2002 Posts 18,022 Location London & Singapore Right-click->Properties->Security tab. Add and remove users/groups and set permissions as desired.
3 Dec 2006 at 15:10 #4 Tony Williams Tony Williams Soldato Joined 13 Jul 2006 Posts 3,371 Location Hell!! \m/ FolderLock does a great job, it even hides the folder from Windows. You can also encrpyt the fiels. It's a 30 day trial.
3 Dec 2006 at 15:19 #5 nemtizz nemtizz Soldato OP Joined 16 May 2006 Posts 14,699 bledd. said: hiding the porn is it? Click to expand... Not atall, im the only person who uses this computer. ITS MINE. Thanks tony ill try it out.
