Hi,
I'm looking at adding some more cables to the house network and as I use a structured cabling approach I use a patch panel. I've found a used, cheap 24 port panel which states it is Cat 4. I was wondering if there was any difference between a Cat 4 patch panel and Cat 6? I've got no problem going for the specified Cat 6 if required, but would be good to know how far a cat 4 panel may go?
Thanks,
Chris
Thanks,
Chris
