Had Virgin broadband for about 6 weeks now. I'm pleased with the download speeds but the router is rubbish. The signal is very poor and the wireless connection is sporadic. I live in an old house with thick walls. I upgraded the wireless cards in the PCs in the house which fixed the wireless stability issues for a time. However, now I cannot connect at all over WiFi. I can see the network but it just wont connect even if I am in the same room as the router. PC says the signal is 85% but the connection just times out, same with the Macbook Pro. At the moment I'm having to sit on the floor with an ethernet cable to the router, which isn't ideal, especially as I work from home.
Has anyone else experienced this issue? The web is full of posts of people saying this router is utter crap. Could I buy a better router and use it instead if I can't fix it? Can't really afford to carry on with it because it's now affecting my ability to do my job.
Thanks in advance.
Update: Fixed the issue by turning off firewall filtering and turning down 802.11 mode 300mbps to 145mbps. Still not ideal. I'll keep an eye on it over the next few days. However, my original question still stands: can I use a third party router with Virgin broadband?
Thanks in advance.
