Hey guys,
Wondering if any of you can help me out here. I need to replace the door handle / lock fitting for this old patio door. I'm having some issues finding out what kind will fit.. The measurement between the 2 screws that affix the handle to the door is 100/101mm - It's from the 80s so not sure if it will have been metric measurements or something fruity like 3-15/16" ...
What measurements are used to classify the PZ notation I see on many of the online listings for sliding door handles? It's a mine field!
Oh we have a hefty deadbolt that goes into the floor so it's not a pressing security concern
Thanks!
Thanks!
